Kassenbon darstellung
brankor
Beitrag von brankor »
Hallo, ich nutze Version 2.9.1. Beim Kassenbondruck werden – falls die Artikelbeschreibung länger als 22 Zeichen ist – der Bruttopreis und die Gesamtsumme nach links verschoben. Ich habe dafür einen Workaround gefunden und möchte ihn gerne teilen.
In /php/utilities/layouter.php
Funktion render() alt:
public function render($varcontent, $just, $label, $varstyle, $useColonAfterLabel) {
    $endOfLabel = "";
    if ($useColonAfterLabel) {
        $endOfLabel = ":";
    if (is_null($varcontent)) {
        $text = $label;
    } else {
        $text = $varcontent;
        if ($label != "") {
            $text = $label.$endOfLabel.$varcontent;
    $textInCp437 = self::asciiEncodeStringTo437($text);
    $contentLength = 0;
    $factor = 1;
    if (($varstyle == self::$NORMAL) || ($varstyle == self::$HIGH)) {
        $contentLength = strlen($textInCp437);
        $factor = 1;
    } else if ($varstyle == self::$WIDE) {
        $contentLength = strlen($textInCp437) * 2;
        $factor = 2;
    } else if ($varstyle == self::$WIDEHIGH) {
        $factor = 2;
    if ($just == ColProperty::$COMPLETE) {
        if ($contentLength > $this->length) {
            $textLines = array();
            $remaingText = $text;
            while (strlen($remaingText) > 0) {
                $textToSplit = $remaingText;
                $maxLength = strlen($textToSplit) * $factor;
                $cutLength = min($maxLength, $this->length / $factor);
                $textLines[] = substr($textToSplit, 0, $cutLength);
                $remaingText = substr($textToSplit, $cutLength);
            $text = implode("\n", $textLines);
        return $this->textOutDueToFont(0, $text, 0, $varstyle);
    $textlen = $contentLength;
        $text = substr($text, 0, $this->length / $factor);
        $textlen = $this->length;
    $freeSpace = $this->length - $textlen;
    $fillstart = 0;
    $fillend = $freeSpace;
    if ($just == self::$RIGHT) {
        $fillstart = intval($freeSpace);
        $fillend = 0;
    } else if ($just == self::$CENTER) {
        $fillstart = intval($freeSpace / 2);
        $fillend = $freeSpace - $fillstart;
    $out = $this->textOutDueToFont($fillstart, $text, $fillend, $varstyle);
    return $out;
neue:
    $endOfLabel = $useColonAfterLabel ? ":" : "";
        $text = $label;
    } else {
        $text = ($label != "") ? ($label.$endOfLabel.$varcontent) : $varcontent;
    $text = rtrim($text);
    // helper: entfernt ESC t n (Codepage-Umschaltung) aus der Längenberechnung
    $stripEsc = function ($s) {
        return preg_replace('/\x1Bt./s', '', $s);
    $factor = 1;
    if (($varstyle == self::$WIDE) || ($varstyle == self::$WIDEHIGH))
        $factor = 2;
    //Länge für das Layout (basierend auf dem kodierten String)
    $encoded = self::asciiEncodeStringTo437($text);
    $contentLength = strlen($stripEsc($encoded)) * $factor;
    //TRUNCATE: Text kürzen und danach UNBEDINGT die tatsächliche Länge neu berechnen
        $maxChars = intdiv($this->length, $factor);
        if (function_exists('mb_substr')) {
            $text = mb_substr($text, 0, $maxChars, 'UTF-8');
        } else {
            $text = substr($text, 0, $maxChars);
        $encoded2 = self::asciiEncodeStringTo437($text);
        $textlen = strlen($stripEsc($encoded2)) * $factor;
        if ($textlen > $this->length)
            $textlen = $this->length; // safety
    if ($freeSpace < 0)
        $freeSpace = 0;
    $fillstart = 0;
        $fillend = 0;
    return $this->textOutDueToFont($fillstart, $text, $fillend, $varstyle);
